The drivers are the B&C 15HPL76W, I've had them sitting on a shelf for a while, debating what I was going to do with them. I've got another pair loaded into a pair of two trap boxes, which are not used often, although they work well as a "full range" on sticks-they only weigh 54lbs., using 18mm Baltic Birch. Anyway, the need for a small pair of subs won out, as I don't have any since upgrading my JTR Growlers to Orbit Shifters a while ago.
So, some design work on the 15HPL yielded decent numbers for the driver, about a 5.5cuft cabinet, tuned to give an F3 of 38hz, and at the rms rating of the driver(350watts), very minimal overlap of the mechanical vs. electrical power limits. Also, the predicted response is pretty flat.
The cabinets are 15mm Baltic Birch, handles and input plate are fully recessed(separate pieces of plywood with extra cutout mounted from the inside of the cabinet). Large, oversize rectangular port on the bottom. The cabinet would accept a driver with 20-30% Xmax if needed because of the oversized port. This keeps vent velocity down.
I framed out the driver with a mounting area for a minimal sized perforated metal grill partly to save some weight, partly to add strength. I was shooting for a 50lbs. total weight, but I don't think I hit it, I still have to weigh it. Still, it's pretty light.
Had them shot at the Line-X shop yesterday.
Best regards,
John
![002.jpg 002.jpg](https://soundforums.net/community/data/attachments/5/5270-f11b47638183fedefa8a1a6eac38b7be.jpg)
![001.jpg 001.jpg](https://soundforums.net/community/data/attachments/5/5271-db0cc77a81b3524f70cfa3e69a2d6759.jpg)
Best regards,
John
