Lectrosonics D4 System
Bennett Prescott
Just This Guy, You Know?
Staff member
Jan 10, 2011
10,858
40
48
40
Wallingford, CT
www.bennettprescott.com
d4_system_manualcover.jpgI first had a chance to use the Lectrosonics D4 system a little over two years ago at the 2010 LAB Expo in Westminster, MA. Howard Kaufman of Lectro brought it to show off, and we ended up using it to get three sub signal lines outside to play around with cardioid and end-fire arrays. Normally I wouldn't expect a wireless system to be able to deliver sub-30Hz energy, but the D4 system did it with ease.
The system uses Lectrosonics' Digital Hybrid wireless technology (US Pat #7,225,135). They have this to say about it:
Digital Hybrid WirelessTM is a revolutionary design that combines digital audio with an analog FM radio link to provide both outstanding audio quality and exemplary, noise-free RF performance.
Using a patented algorithm to encode 24-bit digital audio information in the transmitter into an analog format, the encoded signal is then transmitted over an analog FM wireless link.
At the receiver, the signal is then decoded to restore the original digital audio. This process eliminates compandor artifacts and produces an audio frequency response flat to 20 kHz.
The short story is it's a low bandwidth FM transmission link, which gives the long range of a traditional analog FM signal and can fit more information over the same link. It also offers compander free audio with an extended frequency response, no problem getting 20Hz-20kHz over it. This is the same technology that powers the TM400 system that many measurement techs use to eliminate hundreds of feet of mic cable.
The big difference is that the D4 system can send four independent channels of audio, line level analog or AES digital. Even better, it can convert between the two e.g. input AES audio and output analog. The D4 system can operate in 4 channel mode (4 MHz), or reduced bandwidth 2 channel mode (2MHz) with half the channel width and therefore twice the channel options. The whole system operates from 902-928 MHz at power levels of 200mw, so interference is less of an issue than other frequency ranges and there's plenty of juice for long throws.
Application Specifics
IMG_0424.jpgWhen I learned I had to do a delay tower at 400' for last weekend's gig (for which I used a bunch of EAW KF760) I immediately thought of the D4 system. I emailed Howard and asked if he might have one to spare. Fortunately, he had a D4 system in a nice hard case with all the cables and everything. Not only did he send me a D4 system, he sent me a backup single channel system using their IFB transmitter and R400A receiver.
I had Howard mail the wireless directly to the shop I was working out of, and I drove a truck down full of line array. I also brought helical antennas intending to use them with the D4 system in case I had signal strength problems. What I forgot is that the D4 system uses a little screw on antenna connector, not BNC like my antennas and cabling. So much for planning ahead. The D4 manual has all sorts of warnings about using too high gain an antenna as well, so I don't know whether I could have used the helicals anyway. It sure would be nice to have the option, since getting four channels a long way is a real boon. Perhaps there is an adapter? The IFB backup system has standard BNC antenna connections, so I could have used it with higher gain antennas if I experienced a problem, but it is single channel which isn't as nice.
Fortunately, I had a reasonably clear transmission path, plus the 900MHz spectrum is relatively uncluttered, and I was in the middle of a military base with few major transmitters nearby. As a result, when I put the D4T at my delay tower site I saw almost full signal strength right off the bat. Instead of having to run hundreds of feet of XLR past vendor stalls, over foot paths, and across vehicle access, I just dropped a generator at my delay tower and took my signal over the air.
IMG_0448.jpgBecause I had four channels available, I sent three line array signals down the line (KF760 far, KF760 Mid, and KF730 Near) plus a sub feed directly into the ADRaudio ATA618 cardioid subs. I drove them all directly off a Dolby Lake Processor at FOH so that I could do measurement from there, and maintain control over the separate sections of the array from my tablet all over the field. Incidentally I had much more trouble keeping the tablet connected than I did getting the D4 system operational. The D4R had no apparent problem driving multiple powered subwoofers as well as two DSPs all at the same time. If I were smarter I would have asked to borrow a TM400 system as well so I didn't have to run (well, have David run) 500' of XLR across the field to do my measurements, but I'm obviously not smarter.
I was a little nervous that there would be noise, or dropouts, or perhaps problems due to the heat. I left both ends of the D4 system in direct sunlight and monitored both frequently while setting my delay times, measuring, and through sound check. That signal strength meter hardly budged, and the audio coming out was exactly as expected. If I hadn't known better I would have never known the difference between the D4 system and XLR... except of course I didn't have to run 1600' of XLR!
The D4 system seems to clip at about 0dBu (OK, that's what it says in the manual), so I padded the inputs down at the receiver by 10dB which seemed to do the trick. The meters operate over a very wide scale so it was hard to judge exactly how much headroom I had, but it seemed like even during loud sections I had as much as 10dB. Since the system was relatively noise free I stayed on the safe side and padded a little more than I might have if I was trying to wring every ounce of performance out of normal wireless. No noise, no clipping, all day. I'll have to read the manual a little more carefully to see how exactly I'm supposed to set it up to have a compatible overload point with normal pro audio gear (say, 21dBu or so?) but this worked flawlessly.
IMG_0426.jpgThe show itself went easily. I stopped bothering to check on the Lectrosonics gear after the sun went down, it hadn't delivered a single hiccup all day so with heat out of the question I stopped worrying about it. The show ended with fireworks, which were very well done, and the accolades of the promoter and event manager who were thrilled that we'd gotten audio to the back of the field. I was thrilled that I didn't have to wrap thousands of feet of cabling. One three person crew, myself included, could take down the delay tower and have it back on the truck while the remainder of the crew took down the main stage and its two stacks.
I really appreciated having the D4 system for this show, it made my life a lot easier and meant I could have a lot more lines of audio than I might otherwise have gotten. If it weren't this system, with performance like the TM400 wireless test and measurement system endorsed by so many expert measurement folks, I might not have gone with a wireless solution for this gig. As it was, having the ability to set my delay tower where it was convenient and not have to worry about changing cable lengths if it needed to move, damaged cables from vehicle and foot traffic, filthy cables from the same, and extra time wasted laying out and coiling long runs of XLR, was fantastic.
Knowing how well the D4 system performed at 400', which is a little long for normal delay tower use, I would happily use it at an even longer range. I would certainly like to find out about using more directional antennas, but for this application it was not an issue. Next time I need delays, or need to get full quality audio from one place to another several hundred feet apart for any reason, I sure hope I can get my hands on one of these again. The fact that the whole system fits in a tiny hard case is just another bonus. I don't know what it costs but the TM400 system is very reasonably priced, a real problem solver to be sure.
Re: Lectrosonics D4 System
Hi Bennett,
Great to see the D4 system performed so well for you, I've been itching to try it out for this same application but just haven't quite been able to come up with the excuse to buy one. It really is like having a hard line in the chain, and if you didn't know better I would be surprised if anyone could tell that it was wireless.
On a side note, I don't believe that the D4 system uses digital hybrid, but is a through and through digitally modulated system which allows it to have even wider bandwidth than a digital hybrid system. Perhaps Karl can step in and expand on the technical details.
Either way it sounds fantastic and the performance is amazing. The demo I saw of the Quadra IEM system (which uses the same modulation and encoding scheme) was simply astounding, and even through building walls the range was superb.
Hi Bennett,
Matt, you are correct that the D4 and M4 (Quadra) systems are not Digital Hybrid Wireless, but a completely different technology altogether. They are wide-band digital modulation, basically transmitting 2 or 4 channels of 24-bit, 48 kHz digital. There is some data compression involved, but with David Thomas in our engineering department behind it, the compression is very very good and yields very low distortion or audio artifacts. David is great at making things sound good - he was also behind the design of Digital Hybrid as well.
To Bennett's question about antennas: the FCC Part 15 rules that this device falls under specify the type of antennas and connectors we are allowed to supply with it. On top of that, we can't sell it any other way that how it was tested and certified. That said, it is possible to use other antennas, as long as you have the right adapters (http://www.rfwel.com/shop/RP-SMA-Male-BNC-Female-Adapter.html) to go from RP (reverse polarity) SMA connectors to BNC. PWS makes a helical antenna covering the appropriate frequency range, but looking over their site, it is not clear which one is correct Their data sheets show it topping out at 900 MHz, but we've tested one here that covered 800 M to 1G if I remember correctly.
We make the PCA900 (http://www.lectrosonics.com/393-PCA900/View-details.html?qh=YToxOntpOjA7czo2OiJwY2E5MDAiO30=), which is a mildly directional (think cardioid) antenna also designed for this frequency band - and it's inexpensive. Probably more important that being super-directional would be to have line of sight between transmit and receive antennas. In our tests, this system should go 1200 ft. on a clean frequency, with the supplied antennas, if that gives you any idea. Nevertheless, a helical from PWS would probably extend that range considerably.
Got to use the Lectro stuff again just one week later, at Hartford's annual Riverfest "almost fourth of July" celebration. Five stages on two sides of the CT river running all day, culminating in a fireworks show timed to music. I needed to get program audio throughout the day (for the National Anthem, and then the fireworks music at night) from FOH at the main stage to all the other sites, the furthest being about 3,200 feet away across the river and through some trees. At the same time I needed to get FSK timecode on the other track of the fireworks music CD about 2,000 feet along the river to fire control.
Fortunately, I managed to get some adapters to go from the reverse SMA antenna jacks on the D4 transmitter to standard BNC for my coax run and connection to a helical antenna. UNfortunately, due to the D4 operating in the 900MHz band, where there was already some interference in the area, as well as being outside the bandwidth of the available antennas and amplifiers, in field testing I quickly determined that the D4 system wasn't going to work for me this time. I could just barely get a solid signal on the other side of the river, and it wasn't going to hold up for the long throw to the amphitheater site. Too bad, I was really hoping to test the long throw mettle of the system, but I just didn't have the right antennas and amplifier. Ended up doing it with a Sennheiser 2050 transmitter and a bunch of 500 series receivers in the 500MHz band, but that's a story for another thread. The audio quality out of those was a far cry from what I had hoped the D4 system would deliver!
DSC01460.jpgFortunately (played this game before?) I needed to implement some delay stacks again to extend the coverage of the main system along a long walkway, and out onto a pier. The latter placed speakers just over 100 feet away, but in a place where I would have needed to run over 500' of cable to get there. Enter my convenient cable replacement, the D4 system. Ninety seconds of plugging things together later and I had a strong signal at the delays, and the D4R receiver drove a pair of QSC KW153 speakers directly (into limit all night!). The receiver's output sounded great, I'm sure, and it had plenty of input and output capability to both not get clipped by the FOH mixing console's matrix out and to drive those HPRs to within an inch of their life. How it sounded once it had been run through a tight packed pair of KW153 driven into solid limit I'll leave as an exercise for the reader. I only wish I had several more receivers so I could drop one everywhere I needed a loudspeaker.
The next challenge was to deliver program audio to a stage 200' up behind FOH, unfortunately in the opposite direction that my antennas were already pointing. This audio would be running in between bands on that stage, as well as for the national anthem and fireworks, so it was more critical that it sound good. Fortunately I had the "spare" system that Howard had provided, an IFB transmitter and R400a receiver. The IFB transmitter can easily be configured to use Digital Hybrid transmission technology (really, I checked!). The R400a is the same receiver you would get with a TM400 rig, so both parts are capable of delivering measurement quality audio. The IFB transmitter is also able to take a line level input, and it has an XLR input and standard BNC antenna output. The small screen gives plenty of information, and setup (once I remembered to switch the power from "tune" to "transmit"!) was simple, the included whip antennas gave plenty of output for the 200' throw over a concrete stairway. Much easier than running wire, and certainly much easier to take down at the end of the night! If you only need a single channel, this product operates in the 500MHz band so it fit right into a channel I'd already allocated and could have used our directional antennas if I had ended up needing them.
Long story short, a bummer that I couldn't do my truly long haul audio with the D4 system, but I found a use for both systems Howard provided anyway and they were simple to use and delivered exceptional audio quality. I hope to get my hands on more of this Lectro stuff ASAP, it's my go-to solution for delays. Thanks to Lectro and Howard for providing it, and Karl for chiming in on this thread. They'll probably be wanting their demo gear back now.
