Re: Limiting Within Line Arrays
Just to add some thoughts-about limiters in general. It is often discussed as to what is the best "sounding" limiter? WHO CARES. In fact-a BAD- HORRIBLE sounding limiter is probably better. At least that way-some (not all) operators will actually TURN IT DOWN when it hear it sounding bad-realizing this is the limit-HINT HINT!!!!!!!!!!!!!!!! The other operators will keep turning it up because they think that is way it is "supposed" to sound-since that is all they have been exposed to.
Limiters should be there to PROTECT-NOT as a creative sound tool. Compressors are creative tools-so how they react sonically IS a big deal.
Looking for good sounding limiters is like a girl asking if her new car has PINK AIRBAGS. WHO CARES what color they are-if they protect your life! You should never have to use them-they are "just in case" thing. Bring a bigger rig so you don't have to push it so hard!
Now maybe having a "nice sounding" compressor that kicks in a little bit before you hit the limiters (to give a bit of a cushion) is not a bad idea-but that is a different topic.
But it seems that these days-people are forgetting the whole purpose of limiters. Probably because they don't have a good understanding of how they work-how to set them-what the differences are and so forth. Hell- how many people ACTUALLY MEASURE what the limiters are doing-where they "kick in", how they respond etc? I be VERY VERY few do. I have been spending a lot of time lately looking at how various limiters react-and trust me people-it is NOT what the "simple numbers" on them say it is.
You may "think" that it is doing one thing-but is it really? Just because a couple of flashing LED's go off-does it really mean anything-or mean what you think it means?
MEASURE AND CONFIRM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (and the same goes for the rest of the specs on other products-SPECIFICALLY loudspeakers-but we go there-yet) DON'T just take somebodies word for it.
I bet if you were to ask most people what the differences are (in settings-where to set the threshold-attack and release times etc) between different types and what type is better (power compression-peak-"music power" etc) they could not give you a correct answer. But that doesn't stop them from "talking about them" as if they know what is going on
And why would you choose one type over another-for a particular situation-if you only had one type. For certain types of music (if you only had one limiter and you could adjust it anyway you wanted), I would choose one over another. Change music styles and I would probably want a different type. Depending on the music-the system available-how hard it is going to be pushed and the likely hood of actually hitting the limiters and so forth.
There is no SIMPLE answer! It ALL depends.
If you don't understand the tool and how to use it-it will very often be MISUSED. And then the tool or some other aspect gets blamed. When you bend a nail because you are a lousy carpenter-it is REAL easy to blame the hammer or the nail or the wood it is going into. But if you UNDERSTOOD the parameters around the situation-then YOU would have a much better idea of how to deal with it-and get the nail in nice and straight-with the head right where it needs to be for a particular wood, purpose of nail etc. Finish nails in hardwood floor are very different than nails in a deck. Yet the basic tools (hammer-wood-nails) are the same. How they are used and the intended final usage is what makes you choose a different approach for each one.
And that is another thing that REALLY gets me going-about how LITTLE "the industry" really understands about the gear-what its parameters are-and how gulible they are to marketing-that just seems to totally ignore any real specifications and how many "assumptions" users make based on this "pack of lies".
It is truly amazing to me how some manufactures can throw out a "saying" or a simple single number-and then people "assume" that is correct across the intended usage and how "everything all plays nice and pretty together-so let's all hold hands and smile and have a wonderful day".
It doesn't work that way people.
OK time to get down before I really say what I really think/mean----------------------------------------------------------
