I've noticed some trends in my array designs lately independent of model/manufacturer.
Several auto-design features I've tried in various line-array calculators suggest one should use a very sharp J in the bottom of the array. Sometimes they suggest 0 or 1 degrees for a large part of the array and two or three boxes at the bottom with steep angles, the bottom one often at max. According to the calculators this should give you the a more even SPL distribution across the audience area. But in my experience, using 0 degrees and a sharp J gives you some serious sonic disadvantages, so I don't use this approach.
I tend to prefer arrays with a more gradual curvature, starting with at least 1 degree at the top and finishing at something not to extreme at the bottom. Let's for the sake of this discussion say 2-2-3-4-4-5-6-6. This sounds more pleasing to my ear and those who mix the shows. But sometimes I run into situations where I can't get the array high enough up in the air so the SPL differences gets annoyingly large. I've tried using smaller angles and/or fewer boxes or some gain/eq shading, but this is not always enough.
Is there a third way? How do you guys deploy arrays in small venues with limited ceiling height?
I'm often hired to tech other peoples jobs, so I have limited input on box count and model.
