So, cleaning up shop, I found a TON of copper that I don't really use anymore.
First up, we have an assortment of cables designed to distribute Powercon. They are single gray powercon cable connectors at one end, with a box with three gray powercon outlets at the other end. They are made with 12/3 SJOOW cable. Lengths available are 30, 40, 50, 60, 70, 75, and 100 feet. They were originally built to run to 10' truss, one box per section.
Next up we have a couple Socapex breakouts. A nice male LK 19-pin connectors is wired to 8 stagepin females with 16/3 SJOOW cord. The wiring scheme is alternating hot/neutral until the last two pins, which are ground/ground. (NEC requires two paths to ground, this qualifies. This is how NSI DDS9800 dimmer packs are wired).
I have a single NSI DDS9800 dimmer pack with stagepin and socapex out - 8 channels, 2.4k each. With a breakout above and the onboard stagepins, you can get two fixtures per channel without twofers.
Finally we have standard L14-30 twist cables for amp racks or whatever. Here's what I have:
15,15,35,45,60 foot 10/4 SOOW
70 foot 8/4 SOOW
an L14-30 splitter made with 10/4 SOOW
Most of the items are in the attached pictures.
I'm open to all decent offers on these cables. Remember, this is copper, it's high right now at near $4 per pound, I'm not giving this stuff away. I'll give it to you lower than retail or wholesale wire rates, but again, I'm not going crazy to get rid of this stuff.
silas@concertsunlimited.com / pm / 8603371040
70 foot 8/4 SOOW
