I have a 5 piece band that I run sound for (from the stage, because I'm also the bassist). When the drummer hits his rack tom, I get a low frequency (~100hz) ring through the mains. I can kill the lead vocalists mic (who is located in front of the drum kit) and the ring disappears. Due to the size of my band and the small size of most venues we play, I can't relocate his mic. He's using a Shure SM58. I tried an SM57 to see if it would help and there was no change (which didn't surprise me). I can eq that frequency to reduce it, but then the vocals sound bad. If I turn the subwoofer down it helps, as well but then I don't have any kick drum punch out front. Anyone else have this problem, or have any suggestions? I'm using a Yamaha EMX5016CF powered mixer, so a 9 band graphic eq and the individual eq on the input strips is all I have to work with.
