[FS] MA2 onPC Command Wing
Bryan Smith
4
USA
I'm selling an MA Lighting grandMA2 onPC Command Wing like new in box, the wing was lightly used, it has never toured, only used it twice in a corporate event.
The MA onPC command wing paves the way for mobile use of the highly flexible and powerful grandMA2 control system. In combination with the free of charge grandMA2 onPC software, the MA onPC command wing is a portable 2,048 parameter control solution that can be used in nearly any location. It offers two built-in DMX ports as well as the possibilty to send two additional DMX universes via Ethernet protocols with grandMA2 onPC.
Designed as the perfect hardware expansion to the grandMA2 onPC software, the MA onPC command wing enables the look and feel of the software to be as close to a real grandMA2 console as possible. Thanks to the MA onPC command wing – incorporating the command section of the grandMA2 consoles – it has never been easier to use the grandMA2 onPC software. With a simple USB connection between the MA onPC command wing and the computer running the grandMA2 onPC software, all inputs and outputs of a grandMA2 console are available to the user. DMX, Midi, Timecode and Analogue Remote are all on hand directly at the MA onPC command wing. As a clever detail a slot for a Kensington lock is integrated.
Features:
Real-time control for 2,048 parameters in combination with grandMA2 onPC (up to 65,536 parameters as backup in the MA system)
Expandable up to 4,096 parameter
Command section similar to grandMA2 layout
2 A/B faders (100mm)
1 Level-Wheel
Individually backlit and dimmable silent (clickless) keys
Integrated universal power supply
Light, handy & rock solid
Ergonomic design
Just connect via USB to any PC running grandMA2 onPC
Asking for $4000
Features:
1 Level-Wheel
Ergonomic design
Asking for $4000
Hey Bryan! Is this still for sale?
