Junior Varsity
Mackie M 2600 Channel 2 in protect.
<blockquote data-quote="Lee Douglas" data-source="post: 1302" data-attributes="member: 205"><p>I've got a compact system that uses a Mackie M 2600 on (typically) a pair of four ohm subs. Last time I had it out channel 2 remains in protect, with or without a load after start up. Channel 1 works fine and even got me through the night on a two ohm load. Nothing obviously wrong visually with the top off. Any ideas what may be wrong and where else I might look? Thanks!</p></blockquote><p></p>
[QUOTE="Lee Douglas, post: 1302, member: 205"] I've got a compact system that uses a Mackie M 2600 on (typically) a pair of four ohm subs. Last time I had it out channel 2 remains in protect, with or without a load after start up. Channel 1 works fine and even got me through the night on a two ohm load. Nothing obviously wrong visually with the top off. Any ideas what may be wrong and where else I might look? Thanks! [/QUOTE]
Junior Varsity
