I was in a church near me tonight fixing a recording problem (signal plugged into "output" rather than "input" :yawn
I walked in and closed the door. 3 or 4 seconds later the reverb finished decaying. It's bad enough that you can't understand someone speaking to you from more than 10M away, or AT ALL if they aren't facing you. It's hard plastered concrete and brick, with a smooth wood floor, high ceiling (estimated 15 - 20M). I'd guess it's 15 - 20 M wide and currently about 35M deep.
It seems they meant to build a church but built a gym instead.
The back wall is smooth painted wood and is on rollers so the room can be made longer or shorter.
The "PA" is 2 plastic 15 inch passive speakers by "t.Box" a cheap in-house brand from Thomman, a German retailer. The amplifier is a Thomman "t.amp" of unknown specs. They're on sticks at about head height 2 or 3M from the side walls, 15M "downstage" of the back wall. They're angled roughly 20 degrees in towards the centre.
I think it's these. the box PA502 - Thomann UK Cyberstore
There is loads of headroom, assuming the speakers can take the power the amps have. They're running their input gains about 15db too low and have the master faders at -20 for a normal speech volume. Amps are all the way up.
It was hard to actually hear the PA over all the reverb, but all their HF shelves are at at least +6, and lots are +15. I suspect they would be higher if they went any higher on a Soundcraft M12...
Attached to the wall a further 10M "downstage" is a set of 4 or 5 inch driver monacor speakers getting the same signal. A look around the amp room revealed a seperate amplifier for these but no delay unit. I turned these amps down 10db because of this. It might be an issue when people stand up but it definately helped speech.
Would the best option for intelligibility be to take one t.box, put it in the centre of the room at the front and angle it down?
Would moving the back wall back further help much? My thinking is that if the sound is going to hit it and come back I want it to go through as much air (for attenuation) as possible.
It's highly unlikely they'll be spending any money and I haven't been asked to fix it but because they occasionally ask me to come in for the odd event I'd like to do what I can at those times.
Any recommendations for a cheap but functional line delay unit? Mono would be fine.
I know it needs a total redesign of absolutely everything, but given these circumstances what would be the best deployment of what they have?
Chris
Chris
