Capable of 135dB peak, Martin Audio’s latest announcement, THS, is an extremely powerful point source loudspeaker which combines very high output with extended frequency response. It joins the wider TH series and is ideally suited to medium-scale DJ club applications and installations which call for exceptionally high sound levels from a compact, standalone loudspeaker system.
Packing three high-technology drivers into a relatively small trapezoid enclosure, its innovative three-way triaxial configuration delivers enhanced output for its size and gives it the edge over comparable two-way systems in terms of superior mid- and high-frequency performance. Adding a compact Martin Audio SX subwoofer to extend low frequency output creates a dynamic, four-way set-up with a small footprint.
To ensure the most effective use of amplifier count, THS is designed to be bi-amplified, with an internal passive network performing the mid/high crossover function.
The THS triaxial driver is a...
Continue reading...
