Midas M32c Soundgrid and midi controller
Roland Lanslots
The Netherlands
I'm using M32C with a Waves Soundgrid Card to run SuperRack and plugins. Up till now I've been using a mini PC with a touch screen for controls but I want to add a Waves Fit Controller. This needs to be connected by USB but since I switched Card I don't have a USB anymore. Or can I use the USB on the front??
Any suggestions?? Or am I thinking wrong and should I connect the midi controller to the PC which runs the M32 software??
Help..........
Fit controller doesn’t plug into the M32 at all. It plugs into the HOST PC OR MAC for Waves. Fit controller doesn’t work with SuperRack, it works with LV1. Fit controller can be used as a MIDI controller, and you might program some functions in Super Rack. I have no reason to believe that would work for M32 software. The X Touch has a mode to remote control the X and M.
