Just a few more odds'n'ends I'd like to find new homes for. Looking for fair/best offer on anything that catches your eye:
* FOH Process Rack - $1350 complete or components:
-dbx DriveRack 260 ($500? w/DB9-RS232 cable for DriveWare)
-Yamaha REV500 ($125?)
-Roland SDE1000 ($100?)
-Presonus ACP8 {original model} ($425? w/8ch EWI insert snake)
-Furman AC1215 {true AC regulator} ($200?)
-Samson PowerBrite PRO{pop out flourescent light} ($50?)
-Rack is EWI R8UE (8sp) ($75?)
-Two 4ch 1/4" TRS snakes for FX send/return ($25?)
* 6 Space Shock-Mount Amp Rack w/casterboard - $125
* 12 Mic carrying case w/DI-cable storage - $35
* Pair of (2) EAW LA460 flyable 3-way horn loaded cabinets w/F1 covers - $1600
* Set of (4) standard track Fly Clips - $100
* Custom SpeakOn bi-amp/tri-amp cables, 20' and 40', each has three banana connectors on the amp end, two NL4's on the speaker end. Two banana's are wired to one NL4, the other to pin2 of the other NL4, so one cable can carry a bi-amp signal to one set of speakers with separate subs or whatever combination works for you. Also includes two short banana to speakon adapters, helpful for amps like Lab.Gruppen which don't have banana outputs. I spent nearly $200 having ProCables'n'Sound build these, and they are still in mint condition. Might they still be worth $75 to somebody?
* Truss Arch - this triangular truss archway is something I picked up off eBay for entirely too much money ($850?) way back when. Decent quality for hanging not-too-heavy lighting fixtures over/behind a drummer, or I have even put scrim/spandex between the uprights and used it for rear projection video in a pinch. It has two heavy base/anchor plates. Look up eBay item #150732362994 for a general sense, although this one has more angular connectors rather than a smooth curve. Very open to offers on this.
Available for pickup or reasonable delivery in Boston/New England, or will ship items which can be. Contact by email MikeRussellMail(at)aol.com preferred, or PM if a day or two to hear back is OK.
