Junior Varsity
Mixing from a tablet
<blockquote data-quote="Torbjörn Molin" data-source="post: 4973" data-attributes="member: 925"><p>I just ordered an Idr-32 (iLive stagebox) that I intend to use without a surface, just an Ipad and a laptop. This will primarily be for mixing a band that I work with regularly and shouldn't be a problem as it's the same setup every time, but I'm also thinking about using this for other shows.</p><p>I know that some people on the forum are mixing from tablets regularly, so I wonder, what type of shows do you feel you need an actual surface for and what shows are suited for tablet mixing?</p></blockquote><p></p>
[QUOTE="Torbjörn Molin, post: 4973, member: 925"] I just ordered an Idr-32 (iLive stagebox) that I intend to use without a surface, just an Ipad and a laptop. This will primarily be for mixing a band that I work with regularly and shouldn't be a problem as it's the same setup every time, but I'm also thinking about using this for other shows. I know that some people on the forum are mixing from tablets regularly, so I wonder, what type of shows do you feel you need an actual surface for and what shows are suited for tablet mixing? [/QUOTE]
Junior Varsity
