I had an odd-ball situation pop up, and am looking for advice on my game plan if something similar ends up happening in the future.
I have waited a few weeks and will keep names/places removed to protect the guilty.
I was on a fly date for a house larger than 1000 seats. Really last minute gig and the house sound guy was about an hour late for soundcheck. This left us with less than an hour before doors to get all the mic stands, mics, monitors, cabling and a complete soundcheck done before doors. Monitors were being run by me at FOH.
Usually I try to listen to the house system and walk the coverage to hear what the house is doing before I start checking mics and getting a mix up, however this time I just ran up to FOH and starting working through the lines to get the monitors and my mix up.
As I started checking things, I noticed everything from the house sounded very phase-y and strange.... the musicians on stage were mentioning their wedges sounded very hollow.
After getting about 3/4 of the way through the lines, the reason why it sounded so odd hit me like a ton of bricks. I looked for the graphic EQ's (in the digital console) for the house and the monitors.... and they were hacked to pieces. No band was left untouched (including 20hz and 20k) and there were swings from +11.5 dB to -6dB from one band to the next.
I muted FOH and flattened all the EQ on the monitors, cleared my monitor mix... and got a basic mix for the stage wedges done before we had to bail out and open doors. Pushing the doors back even farther wasn't an option.
First couple songs were a little rough, but after some really fast working/running out in the audience to hear we got the show sounding good.
My question for the more experienced engineers:
When you get put in a venue with strange system tuning what are your priorities if you are extremely short on time? Most house graphs I have run into are either nicely aligned or need small tweaks to suit my tastes/needs.... what do you do when they are not?
Getting the musicians a good mix on stage always is priority one for me (if I am running MON from FOH), but in a throw and go situation, what is your next problem solving stop?
My mistake was (while not thinking clearly) trying to use channel EQ to fix the house before realizing that the house graph was what was screwing me over. Would you immediately flatten the house graph and pull out the main resonances? Or try to individually undo each band hoping to save a little time?
Thanks for the insight!
