Well, out on the road with my StudioLive this weekend. I was excited to be able to use the iPad app to remote control the system. Understanding the shortcomings of the app, I'm prepared to get to work.
I get things all set up, and working, and all is well. Then the iPad went to sleep and every time I tried to connect to the board, it would drop into demo mode. Odd, I thought. Quit the app, and re opened. Same problem. Rebooted the iPad, same problem. O.K, fine, I'll reboot the mac connected to the board. WOAH, don't do that. When you reboot the computer, the board will end up muting several times, even if you quit the app first!! Somehow rebooting the machine with firewire attached sends signals to the board that confuse it. It's only 2-3 seconds, but in the reboot process, it happened 5-6 times!!!
Don't get me wrong, there are things about this board I love, but it seems as though you really have to walk on eggshells when working with it.
After rebooting, the iPad app was working just fine. A test did show that simply restarting the computer will produce these problems. Disconnecting the firewire cable will also sometimes cause the board to mute for a moment, but that's better than muting 5-6 times. Unplug the firewire cable before rebooting your machine.
