Edit:
Rambling post deleted.
Two brand new amps failed on stage and I'm wondering why. Fender "Cyber-twin" and an Ampeg bass amp, both with Class D switching power supplies. Got through sound check and one preperatory number, then both amps failed after the first song. Dead. Nothing else showed any sign of harm and the third amp on stage (an older Fender amp) was good for the rest of their time handling one guitar AND the bass guitar.
Power was from my Honda 3000ei which I have used for 5 years for such gigs with never a problem. In fact, I've used it with twice the system I was using that day. The difference from other years was:
Power to the two failed amps was taken off the same Furman AR1215 line regulator handling side-of-the-stage mix position. The older Fender was powered from a spare outlet on the front of the stage monitor power stringer, so it was not on the line regulator, nor was it a Class D amp.
None of my gear has switching power supplies and none of my gear sustained any damage. I have always run my consoles and processing off of the line regulator since losing a bunch of gear to bad power in my "learning the hard way" years. I have a MixWiz 14:4:2, Sabine GraphiQ, Shure auto-mixers and TCE IIIC multi-band comps in the rack along with a dual-CD "DJ" playback setup. It's all fully-functional.
Question is, why did the brand new amps fail? Why only them and why at the same time?
Thanks in advance for any help in understanding this.
