[FS] Moving light distro
Hello,
Here is a great deal on a well built and versatile moving light power distro. This is a 208v unit made with a square D QO series panel.
Each side of the panel board has 6 L6-20 twist-lock 208v outlets which are all wired in parallel with a 208v socapex output at the bottom. So you have 12 local L6-20 or 2 208v socapex outputs. It is wired internally with THHN stranded wire, and the wiring is VERY tidy and clean. Additionally, there are 4 120v Edison outputs on the bottom.
Inputs are 3 phase cam lock with ground and neutral reversed on about 18" of wire. There is a 3 pole 100A main breaker.
This was purchased with a large lot of equipment from another company, and most of my large scale lighting is handled by a business partner, so I have no need for it. It has seen little use so it's ready for a long life of service.
Because it's a piece of power equipment, buyer assumes all responsibility for it's safe usage and compliance with applicable codes.
Asking $200 + shipping.
Re: Moving light distro
Thanks for those who inquired, and sorry for the delayed response, been working a few large shows.
Shipping would be your choice of carrier, from the 19713 zip code.
Package dimensions would be roughly 36x20x10" and about 50 pounds.
I'll knock $25 off the price to get this thing moved and help with shipping.
Ok...
I just sent a PM...
-AlanH
