DIY Audio
multi pin connectors
<blockquote data-quote="Nick Stone" data-source="post: 348" data-attributes="member: 269"><p>I have a 32 ch system and have been entertaining the idea of using multi pin connectors to speed up set-up time. My system is used with my same band 1-3 times a week and im doing the set up 99% of the time. </p><p> </p><p>Whirlwind Mass or the Ramtech connector seem to be the most robust while EDAC connectors seem to be a lil easier to work on and are most definitely cheaper. </p><p> </p><p>Seems as if a lot of people get a lot of millage out of the edac connectors when properly cared for (empty pin blocks to prevent bent pins) etc. </p><p> </p><p>Crimp tool- ive seen these from 100.00 to 670.00 what should i be looking for here. </p><p> </p><p>Id be interested in hearing any stories , articles or advice that anyone has on this matter. </p><p> </p><p>Thanks.</p></blockquote><p></p>
[QUOTE="Nick Stone, post: 348, member: 269"] I have a 32 ch system and have been entertaining the idea of using multi pin connectors to speed up set-up time. My system is used with my same band 1-3 times a week and im doing the set up 99% of the time. Whirlwind Mass or the Ramtech connector seem to be the most robust while EDAC connectors seem to be a lil easier to work on and are most definitely cheaper. Seems as if a lot of people get a lot of millage out of the edac connectors when properly cared for (empty pin blocks to prevent bent pins) etc. Crimp tool- ive seen these from 100.00 to 670.00 what should i be looking for here. Id be interested in hearing any stories , articles or advice that anyone has on this matter. Thanks. [/QUOTE]
DIY Audio
