Multi Track with X32 Compact & S16 - issue, please Help for tomm....
Nick Andrews
106
Hi,
Sorry for repeat post, I have a gig tomorrow that I will be needing to multi track, I just setup my x32 compact and s16 snake to test everything for tomorrow. The issue is I am not getting any of the signals patched into the S16 into reaper, all the S16 signals are arriving at the console, but not getting to reaper am I missing something ? All my local mic inputs on the console are showing up correctly into reaper just fine. I have the channels in reaper record armed and assigned to the correct inputs in the asio window and setup windows, but no matter what I do, anything that is coming into the S16 does not show up in reaper...
Ps - I have the inputs blocks asigned correctly in the routing tab on the x32 also....
Any help is greatly appreciated!
Thanks!
Nick
Re: Multi Track with X32 Compact & S16 - issue, please Help for tomm....
In the card tab you need to assign the aes50 routing as well.
The card routing is separate from the 'home' routing.
Thanks for your reply Robert,
So on the routing tab if I page over to the card tab, it says "card out" I know that's to asign the outputs of the xuf card to the channels, but I don't see anything as far as assigning the inputs, if possible can you explain further?
Thanks so much...
Nick
Hello
"Card out" is what you are sending out from the desk into your recording device - it can be different from other desk functions - so select what you need to record.
got it !
thankyou so much guys --- have a great weekend!
Nick -
