My BLUE Spark SL.
Nevo Yechieli
pardes hana, israel
Hi, my Blue spark sl don't seems to recognize my audio interface. I'm new here and the microphone is new to me. when I plug it in the interface it flashes a few times, and then it's not picking my voice. I'm using a cheap (Realy cheap)Audio interface, it's called "Behringer U Phoria um2". I plug everything correctly, the cable first, then the phantom power. please, I really Need your help !
Your mic doesn't 'recognize' an audio interface, the mic isn't a computer sort of device. The mic draws power from the interface ( if you've turned on the 48v switch ) and then the mic turns sound waves into electrical signals that are then amplified by the mic preamp portion of your interface and then turned into computer data by the A to D convertor portion of the interface. If your interface works correctly with other mics that require phantom power then it sounds like the Blue Spark has a problem.
