Thanks, busy the next few days and not sure how to search for this.
Small Signal Parameters: Fs 28 Hz
Re 4.6 ohms Qts 0.226
Qms 2.28
Qes 0.251
Vas 425 L (15 ft3) 0 3.38 %
Le 1.6 mH
Large Signal Parameters: Sd 0.1195 m2 (185 in2) Xmax ±12.7 mm (±0.50 in) Vd 1520 cm3 (93 in3)
Mounting Information:
Diameter:
Bolt Circle: Baffle Cutout: Depth:
Net Weight: Shipping Weight:
470 mm (18.5 in) 438 mm (17.24 in) 422 mm (16.6 in) 206 mm (8.12 in) 12kg(26lbs5oz) 13.5kg (29 lbs)
Qms 2.28
Qes 0.251
Le 1.6 mH
Diameter:
