Re: New version of Yamaha Stage Mix is out
Anyone have a wireless access point worked out for StageMix that you're impressed with?
From the manual:
WiFi access point (preferably with 802.11n, 5GHz capability, though 2.4GHz and 802.11g will also work)
802.11n networks at 5GHz are preferred because they allow faster communication between the iPad and the WiFi access point. Practically, this could result in more accurate level metering with the StageMix app. Also, with 802.11n being a new standard, it is less prone to interference from other wireless networks. Using a WiFi access point with 2 or more external aerials is recommended to increase potential signal range. Booster aerials could be connected for a further increase in performance.
Thanks.
