so the article says that the 'painful' frequencies are between 2k and 4k. well, i could have told you that...
i like to call it the 'JBL effect'...
Yes, but now we have scientific confirmation.
Exposure to loud sound can cause temporary shifts in the threshold of hearing (TTS) in the mid frequency region, greater than 20 dB at 4000 Hz is common with exposure to loud music.Interesting read,
I had a "hurtful" audio experience when I was called on to mix monitors for a Scottish act. It was a sort of modern pipe band with some synthesisers playing drones and maybe a bass player, some vocals and about thirty bagpipers. The room was about a 2000 seater with quite a bit of wood and plaster. Monitor position stage left under a balcony. Being that close to 30 bagpipes is quite something; they're loud with a lot of energy at the "hurty" frequencies. The interesting thing was that they would start each song with a skirl of the pipes, which would be like an all-out assault on my eardrums, then the bass and synths would kick in with some low end and then the painful aspect of the pipes would reduce markedly. Same, if not greater, SPL arriving at my ears, but remarkably less offensive with a fuller spectral content than the pipes by themselves.
What I learnt from the experience was, that if your mix isn't sounding that great, just turn the bass up and it will instantly improve. Works for me.
Chur,
Andy.
Interesting read,
..... The room..... 30 bagpipes.....
Andy.
Since I am/was an oboe player (yes-true- I wanted to be "different"), I feel obligated to say this.There's your problem. Those words should never be in the same paragraph.:evil:
Not sure where you are, but around here, the Musicians' Union doesn't represent bagpipers. Bagpipes aren't musical instruments, they're weapons of war!
GTD
Here is a fun experiment to try.The interesting thing was that they would start each song with a skirl of the pipes, which would be like an all-out assault on my eardrums, then the bass and synths would kick in with some low end and then the painful aspect of the pipes would reduce markedly. Same, if not greater, SPL arriving at my ears, but remarkably less offensive with a fuller spectral content than the pipes by themselves.
