Re: Not a stage collapse but very bad
A death whether from a collapsed stage or electrocution is still a needless death.
"Officials are investigating what went wrong, but initial reports cited
faulty wiring on his microphone as the cause of the electric shock."
And another example of poor reporting.
A miswired mic does not have the potential to kill.
Figure either a fault in the PA console where the chassis became hot (which would have affected all mics) and would still need a path to ground,
As Mr. Briolini not only was the lead singer, he also played electric guitar.
So the more likely scenario was some type of amp faullt (hot chassis?, cut off ground pin? etc.) where full power was on the strings, and when he grabbed the mic, he completed the circuit to ground.
Mics generally connect the shield to the mic body.
The other possibility was a faulty outlet - RPBG - reverse polarity bootleg ground which would have made the chassis hot (through the amp ground), feeding hot through the cable shield to the guitar strings... Holding the hot guitar and grabbing the grounded mic -
The mic is always the fall guy for other faults that kill.
A GFCI on the backline stringer would have prevented this tragedy.
Testing guitar/mic with NCVT would have revealed the fault.
Bumping strings (don't hold any metal of the guitar) to the mic stand/microphone and see if sparks
(not recommended, but better than grabbing either guitar or mic) Brush strings and brush knuckles or back of hand to stand - if hot, the muscles in your hand will contract - basically releasing you from the danger.
Brushing the inside of your hand (or grabbing) will also cause muscle contraction, but the contraction will cause the hand to close with the inability to let go. With the guitar in one hand and the mic in the other, the inability to let go will put many times more current across your chest which will kill you.
A long, and better discussion of the problem, cause, and preventative measures at this link:
http://forums.prosoundweb.com/index.php/topic,152464.0.html
frank
