Junior Varsity
PA Setup Question
<blockquote data-quote="Brian Murphy" data-source="post: 4779" data-attributes="member: 1805"><p>Hello everyone.</p><p></p><p>I find myself in the position of trying to be tactful and practical at the same time which is sometimes not easy.</p><p>I'm in a weekend warrior band which has a so-so PA consisting of Mackie 450's and a Behringer powered mixer. There is very little interest in spending any money on upgrading the PA. Most times the EQ and levels are off because the PA is run from the stage. A lot of these gigs don't pay enough to justify hiring a soundman and if they did it's doubtful the other members would go for it anyway.</p><p></p><p>I'm thinking of using a snake(I have one) to run an EQ out 50' from the stage, set it and then bring the EQ back and run it direct to the mixer so that no one messes with it. Bad idea, better than nothing, more practical solution?</p><p></p><p>Thank you,</p><p></p><p>Murph.......</p></blockquote><p></p>
[QUOTE="Brian Murphy, post: 4779, member: 1805"] Hello everyone. I find myself in the position of trying to be tactful and practical at the same time which is sometimes not easy. I'm in a weekend warrior band which has a so-so PA consisting of Mackie 450's and a Behringer powered mixer. There is very little interest in spending any money on upgrading the PA. Most times the EQ and levels are off because the PA is run from the stage. A lot of these gigs don't pay enough to justify hiring a soundman and if they did it's doubtful the other members would go for it anyway. I'm thinking of using a snake(I have one) to run an EQ out 50' from the stage, set it and then bring the EQ back and run it direct to the mixer so that no one messes with it. Bad idea, better than nothing, more practical solution? Thank you, Murph....... [/QUOTE]
Junior Varsity
PA Setup Question
