Re: PM4000 trouble shooting help
I'm helping work on an old ( like there are any new ones) a PM4000 that has hum issues. All of the aux outs have a light to moderate amount of hum on them, turning the aux masters up and down does increase and decrease the hum. The main stereo and group outs have slight amount of hum. The matrix outs are clean with all the matrix main levels up and the matrix inputs all down, bringing up any of the matrix inputs will bring the hum into the matrix outs. All of the channel inputs are off the auxes are off. Changing power supplies did not help.
My theory is that possibly there is a channel module that is causing the the hum directly on the busses regardless of the mode the channel is in.
Short of pulling all of the channel modules does anyone have any ideas?
Can you pull and replace the channel modules with the board powered up?
Thanks
Mike C.
First, no, you cannot hot swap modules in the PM4000s (you could on the old PM3000s, can't believe I remember that). There is a pico fuse that will blow and need replacing. I did it only once. This info comes from one of the great analog console gurus, Rex Ray.
Aside from that, it's pretty easy to pull the modules and then replace them one by one in order from outputs to inputs to see if there is a particular module causing problems. I would do general housekeeping things first. You'll have to pull all of the modules to perform the following chores. Use star washers on the screws on the back of the module where it screws to the frame (hence, the 4K "Star-ground mod"..
) While the modules are out, tighten everything in sight, especially ground wires that are attached to big copper blocks. Also, check inside the PSU and look for a copper block with ground wires screwed to it (I realize that swapping PSUs didn't help, but again part of the housekeeping). Again, make sure they are all tight. And I use Caig Deoxit to spray module contacts and their mates inside the frame.
From here, I'd start checking individual modules.
It's been a while since I refurbed the ones we had, I'll post back if I remember anything. I am in no way a guru on these things, I learned what I know from several phone calls with the ever-generous-with-his-time Rex Ray. I tried not to bug him too much, but when I did, I had a notebook and pen ready. Talk about a walking encyclopedia....
Geri O
