PM5D Mix send follows cue function?
Re: PM5D Mix send follows cue function?
In sends on fader mode the M7CL will bring up mix sends on faders when you cue up a mix in the master section.
Same with VENUE models. Is there a way to do this on PM5D? I have searched.
Hit the fader flip on the left of the console, use the 24 mix select buttons right below it, if you tap them a second time, that mix is cued up as well.
