Power Supply
Raymond Feiler
5
Kentucky, USA
I have a powered floor monitor that I got from Germany. It is currently setup for 220/240 Volts. To use it in the States do I just need to change out the fuse and power cord?
From the manual;
Thanks for the response David. I guess I was hoping that the SMPS (switched-mode power supply) was the capable of both sources but would draw twice the amps if only supplied with 120 volts. But the way they have it labeled I think you are right.
I got this response from DB Technologies. :)(y)
Dear Raymond
Unfortunately if you change only the fuse is not enough.
You have to add a Jumper connector into your amplifier, see below.
