Hello All,
I have been on the lookout for a replacement for my smallest digital board, the Ederol, which is no longer made.
(I still have it, but it is in a permanent install.)
My main concern is a digital snake. In fact the PreSonus line has been out for me because of no digital snake.
I do like the sound of the board, despite my trepidation because of my use of the 8ch comp/gates.
Anyway, someone emailed me a link to this. I called my dealer and talked some to him.
I want to use it for live, he is completely stuck on this being used for recording, and that I should get a StudioLive if I want to do live work.
I have determined that this (VSL) is completely in line with what I want or need.
But I have one question that I cannot find the answer to.
Is the computer part of the signal chain, or only a controller?
As in, can I set it up, and then disconnect the computer and the same mix continue?
(My dealer gets completely stuck at this point, and states that the recording or playback would stop then.)
http://www.presonus.com/products/Detail.aspx?ProductId=65
Regards, Jack
Regards, Jack
