Pro 1 question
Randy Gartner
465
Pennsylvania
randygartnersound.com
Normally,the input button light is lit.But if I select a pop group or hit some other buttons,the input light will go out and I can't scroll through the inputs. This happened before but i was always able to get it back.This time the I can't.What is the sure fire way to get the input light activated?
Re: Pro 1 question
What are you referring to as the "input light"?
Assuming its the channel select button, if you select a POP Group...the channels spill out.....simply press the Pop Group again to exit the group and return to normal lay out. A "checker-board" background will indicate which "button" is pressed. Works for both VCAs and POP Groups. If you have pressed an Aux send, press the Clear button or press the Aux send button a second time to exit flip mode and return to normal layout.
Good luck.
