Producer fader sticking
Mick Berg
227
I have a Producer console mounted vertically in a rack. One of the faders does not move freely so if I change layers It does not move up to the zero position. Is there an easy fix for this, I don't want to send the mixer in, it is used every day.
Mick Berg
Re: Producer fader sticking
Mick Berg
Hi Mick,
Patrick here from Behringer - MUS!C, we would like to help with this matter, if possible can you send us an email to [email protected] and our Tech team will take a look and find an appropriate solution.
Many thanks.
Is this an x32?
Could it be that the fader belt has slipped off its cog wheel? That should be fairly easy to fix. I know that there is a video on youtube somewhere.
Hi Robert.
Don't think that's it, it moves halfway up. It's a Producer so I guess it is an X32.
Mick
Hi Robert.
Mick
I seem to have fixed it. I held the fader knob at the zero position so it couldn't move and changed layers a few times. Now it works fine. What did I do? And will it last?
Mick
Mick
If the cog wheel was slightly loose then the friction may have caused it to get a better grip when you held it. If it will last? Probably not, but you'll never know.
I was wondering if a foreign object got in there and I un-knowingly dislodged it. I'm going to dismantle an X32 this afternoon so I'll have a better idea of how the faders work.
