I need a box for dry rentals that has RCA inputs and a mic-level input. Let me know if you have some used and in good condition. Thanks.
I have a sad face available for free:
What, exactly, is this sad face in reaction to? The giving of my money to manufacturers making cheap, crappy boxes?
Dude, I'm totally with you on this. That panel is a nightmare. This is really just a vestige of my bias for QSC gear because I'm already using the KW line for larger shows.I can see where having RCA on a speaker is useful, but I have owned k series and renting them out without a big full-color document explaining where to plug things in guarantees you're getting a phone call.
I worried about the complexity of that panel when I switched my small stuff over to the K10. Turned out not to be much of a problem. Oddly enough... the fact that it looks more complicated seems to make people stop and think about it for a second. Back when I had powered boxes for this purpose with only XLR in and out a a couple of dials, I would regularly get calls from people saying "it doesn't work!"... and it turned out to be that they'd forgotten to plug the power cord in. With the K10, I get less calls like that. People seem to figure it out. I do put gaff tape over the inputs that they shouldn't use. I think that helps. If you tape off the A side, you also don't have to worry about them plugging a line source into it and switching the thing over to "mic" level.
Having used them as my "small speaker" for several years now, I still like them a lot. Because they sound good up to a pretty loud volume, I can handle just about everything in that 'small' range with them -- public speaking, house parties, in-store DJs, spread around for large events... sometimes as stage monitors. They're a great multi-use tool. It means I can cover a whole lot of market segments with just one box.
