Question on JBL SR4731A input panel
Gary Weller
103
Il.
I've got a question about the input panel on a jbl SR4731A. I'm going to start bi-amping them, but I won't have my 4-wire speakon cables made until next week. What I am wondering (called jbl and they didn't know) and I couldn't tell by looking at the pdf on the input panel is whether I can use both the speakon 1+, 1- input (for the mids) using my current jumper from my subs and use the 1/4" high jacks at the same time (after setting the cab to bi-amp mode).
Hope I'm being clear enough,
Anyone here know for sure?
Re: Question on JBL SR4731A input panel
Try it and find out. In your garage, rehearsal space, even your living room.
The important question is if the 1/4" HF jacks are "switching." Do they disconnect the HF from the internal crossover?
"Do they disconnect the HF from the internal crossover?"
You know, I think they don't. I have a pair of those speakers and I think that even in the bi-amp mode the passive crossover serves as back-up protection. Lately I have been using them in the passive mode as a front fill speaker. I've never had the need to use them in the way mentioned so I don't really know, but as Tim said, give it a try.
I found a schematic on jblproservice.com... http://www.jblproservice.com/pdf/SR-Series/SR4731A.pdf It needs some cleanup to be legible but it looks like at least one jack is a switcher.
