Re: Question
An even better question is how do you use an analog graphic EQ with a digital console, if you're using only digital outputs (like AES or networked audio)?
I'd say a DSP isn't worth using if it's not networkable. If it's networkable put it on the stage where it belongs.
I've made the commitment to switch my entire rig to network audio/digital everything. I don't use analog gear, at all--nor could I.
PS- you should still be able to insert it, but with lots of additional AD/DA and latency. The difference is audible.
