Junior Varsity
RCF L15-542 Driver replacement / substitute
<blockquote data-quote="Ben Lawrence" data-source="post: 3532" data-attributes="member: 391"><p>Hello,</p><p>I picked up a lot of used equipment off a small venue a few years back. Part of it was some old EAW FR253HR speakers. I have since pulled them apart and am trying to replace the 15" stock drivers. I have contacted the EAW parts vendor and these 15's are upwards of 200$ each to replace. Reconing is not that much cheaper. In addition there is one oddball LC-1523 driver and 3 L15-542 drivers. I was curious if there might be a cheap Eminence, Dayton or the like that might work in these cabinets with decent results. I pulled these specs off the web for the original drivers. Any assistance would be appreciated as long as it doesn't involve carrying these things up a flight of stairs.</p><p>[TABLE="class: tborder postborder, width: 100%, align: center"]</p><p>[TR]</p><p>[TD="class: alt1 post2, bgcolor: #BBBBEB"]Mms 84</p><p>Cms 0.00014</p><p>Fs 45</p><p>Qts 0.36</p><p>Qms 9</p><p>Qes 0.37</p><p>Vas 146</p><p>Re 7.2</p><p>SD 850</p><p>Xlin 4.5</p><p></p><p></p><p>[/TD]</p><p>[/TR]</p><p>[/TABLE]</p></blockquote><p></p>
[QUOTE="Ben Lawrence, post: 3532, member: 391"] Hello, I picked up a lot of used equipment off a small venue a few years back. Part of it was some old EAW FR253HR speakers. I have since pulled them apart and am trying to replace the 15" stock drivers. I have contacted the EAW parts vendor and these 15's are upwards of 200$ each to replace. Reconing is not that much cheaper. In addition there is one oddball LC-1523 driver and 3 L15-542 drivers. I was curious if there might be a cheap Eminence, Dayton or the like that might work in these cabinets with decent results. I pulled these specs off the web for the original drivers. Any assistance would be appreciated as long as it doesn't involve carrying these things up a flight of stairs. [TABLE="class: tborder postborder, width: 100%, align: center"] [TR] [TD="class: alt1 post2, bgcolor: #BBBBEB"]Mms 84 Cms 0.00014 Fs 45 Qts 0.36 Qms 9 Qes 0.37 Vas 146 Re 7.2 SD 850 Xlin 4.5 [/TD] [/TR] [/TABLE] [/QUOTE]
Junior Varsity
