Junior Varsity
Reinforcement vs. amplification
<blockquote data-quote="Jay Barracato" data-source="post: 4543" data-attributes="member: 24"><p>I had an interesting show Saturday night that brought to mind the difference between amplifying a band and reinforcing a band.</p><p></p><p>This was a local big band doing a tribute to Count Basie. The show was basically a mc narrating significant events etc. from Count Basie's life interspersed with many of his best known tunes.</p><p></p><p>For inputs, I had</p><p></p><p>the mc mic</p><p></p><p>the electric piano di</p><p></p><p>the bass di</p><p></p><p>2 KSM27's for sax solos</p><p></p><p>2 SM81's for trombone and trumpet solos</p><p></p><p>Everything was set to enhance the stage volume rather than replace it. The band had great dynamics and I was able to set my levels so when one of the horns stood to solo, the mic just lifted the solo instrument out of the mix and moved the image to the front.</p><p></p><p>The bassist had especially nice tone, and given that I like upright bass, I did probably have him slightly stronger than typical, but once again with the whole band playing, he was nicely blended into the mix, but when the band pulled back to just the rhythm section, the bass had great presence and tone and each note was clear. While the system had aux feed subs, I did not use them at all, I just ran the bass through the full range tops. I am not sure what the pickup system on the bass was, but I picked the signal directly from the DI on his amp (sometimes chancy but worked this time).</p><p></p><p>Well for a Count Basie tribute, the piano must be fairly important, and due to stage size the band was limited to an electric piano. Originally I patched the piano in stereo through a radial DI, but found out at the last minute that he was only going to run mono. With digital at FOH, the easiest path was to simply patch that mono input to both L/R. Other than the MC mic, I had gone into the show thinking that the piano would be the only thing I needed in the FOH mix, and I was worried about the location of the image coming from the speakers rather than the stage. Initially I delayed the outputs, to try and push the speakers back to the middle of the stage, but due to the shape of the room, I didn't like that. I ended up just leaving them, and I liked the way the piano solos came forward in the mix through the speakers. The same thing was happening with the horns, but because they had a significant stage volume it wasn't as noticable. I really liked the effect for the piano.</p><p></p><p>A couple of photos</p><p></p><p></p><p>[ATTACH]156480[/ATTACH]</p><p></p><p>[ATTACH]156479[/ATTACH]</p><p></p><p>[ATTACH]156478[/ATTACH]</p></blockquote><p></p>
[QUOTE="Jay Barracato, post: 4543, member: 24"] I had an interesting show Saturday night that brought to mind the difference between amplifying a band and reinforcing a band. This was a local big band doing a tribute to Count Basie. The show was basically a mc narrating significant events etc. from Count Basie's life interspersed with many of his best known tunes. For inputs, I had the mc mic the electric piano di the bass di 2 KSM27's for sax solos 2 SM81's for trombone and trumpet solos Everything was set to enhance the stage volume rather than replace it. The band had great dynamics and I was able to set my levels so when one of the horns stood to solo, the mic just lifted the solo instrument out of the mix and moved the image to the front. The bassist had especially nice tone, and given that I like upright bass, I did probably have him slightly stronger than typical, but once again with the whole band playing, he was nicely blended into the mix, but when the band pulled back to just the rhythm section, the bass had great presence and tone and each note was clear. While the system had aux feed subs, I did not use them at all, I just ran the bass through the full range tops. I am not sure what the pickup system on the bass was, but I picked the signal directly from the DI on his amp (sometimes chancy but worked this time). Well for a Count Basie tribute, the piano must be fairly important, and due to stage size the band was limited to an electric piano. Originally I patched the piano in stereo through a radial DI, but found out at the last minute that he was only going to run mono. With digital at FOH, the easiest path was to simply patch that mono input to both L/R. Other than the MC mic, I had gone into the show thinking that the piano would be the only thing I needed in the FOH mix, and I was worried about the location of the image coming from the speakers rather than the stage. Initially I delayed the outputs, to try and push the speakers back to the middle of the stage, but due to the shape of the room, I didn't like that. I ended up just leaving them, and I liked the way the piano solos came forward in the mix through the speakers. The same thing was happening with the horns, but because they had a significant stage volume it wasn't as noticable. I really liked the effect for the piano. A couple of photos [ATTACH=CONFIG]156480.vB5-legacyid=3859[/ATTACH] [ATTACH=CONFIG]156479.vB5-legacyid=3858[/ATTACH] [ATTACH=CONFIG]156478.vB5-legacyid=3857[/ATTACH] [/QUOTE]
Junior Varsity
