Rugged external hard drives
Re: Rugged external hard drives
I knew the lacie drives would be the first recommended. I've killed 2 of them now, so I'm looking to try a new brand...
Define "kill". If the internal drive is dead, switching brands won't help much. If it's the outer enclosure/electronics, that may be a different story.
Have you considered a small Pelican case or Otterbox to store the drive in?
The drive itself just doesn't seem to last. Both have developed the clicks and are completely unreadable...
That's got nothing to do with the enclosure and everything to do with abuse. You can just pop a new drive into your existing enclosure and it will be fine, till you drop it again. I highly recommend Hitachi drives for reliability, since they bought IBM's server hard drive division and those were some of the best drives made.
+1
Buy any enclosure with a Seagate or Hitachi drive, or replace the drive in your existing enclosure with one. Then buy a Pelican/Hardigg to put the drive and cables in.
I have two of these enclosures, firewire 400/800/USB2.0/eSATA, with 7200RPM 500MB drives in them, and they have served me well. The main case is metal but the sides are plastic. They have no fan so they're pretty quiet (just the hard drives themselves make noise, and I picked low-noise drives when I put them in).
http://www.acomdata.com/p-262-samba-quad-interface-external-enclosure.aspx
If I were you, and I wanted firewire (I'm assuming you want firewire 800) then I'd buy enclosures, whatever you do. It's cheaper in the long run, and you have more choices for drives. You can put in whatever reliable 3.5" drive you want, whatever speed and size, including SSD's if you want no moving parts for extra robustness. Not that I'm necessarily recommending SSD for your particular application - you'll want to research that thoroughly as they have their own problems....
Hope this helps,
...Greg
EDIT: I see others posted since I wrote that, was late in posting. The lacie enclosure you have looks pretty rugged to me. Can't recommend a more rugged 3.5" drive than the others mentioned, except possibly SSD....
My day job is in IT, and part of my responsibility is overseeing all my company's desktops and laptops. I have replaced failed drives from absolutely every manufacturer - IBM, Toshiba, Samsung, Hitachi, Seagate, WD, etc. As a company, we made the move to SSDs about 2 years ago, both for performance reasons, and also because rebuilding dead laptops was taking a big chunk of my time. I've replaced one dead SSD, but other than that, there has been a huge reliability improvement from moving to SSDs, and for corporate use an 80 or 128GB drive is perfectly adequate.
I don't believe the linkage between IBM's server drive technology and their workstation drive technology is as strong as you make it out to be - there are major differences between a 100% duty cycle server/SAN drive and a much lower duty cycle workstation drive.
I believe Seagate and Hitachi are as good as anyone else, but the only way to keep important data on hard drives is to have multiple copies. As you suggest, the expected service life of any particular drive is closely related to how it has lived, and is IMO much less closely related to what brand it is.
Seagate FreeAgent GoFlex is my drive of choice. But as others have mentioned, it generally isn't the brand of drive, but rather the treatment of the drive (vibrations, shock, etc) that is the general end of the device.
You could get crafty and mod up one of the small pelican camera cases and mount a drive like the seagate in there in foam and have yourself a nice little very rugged portable drive.
In addition to this, server, or "enterprise" class drives typically offer lower error rates (100 to 1000 times lower) and are often made of sturdier materials. There is a trend as of late where manufacturers have begun to sell "near-enterprise" class drives. There increased reliability over standard consumer drives is a gray area.
Personally... and this is only my personal experience, I've had pretty terrible luck with Seagate over the years. Most of my drives are Western Digital, and I've had several Maxtors as well (they are now part of Seagate). I used to buy IBM drives back in the day, but they had a HUGE issue with there Deskstar 75GXP drives (a.k.a. "Deathstar") which led to a lawsuit and terrible reviews. They lost a lot of credibility after that fiasco.
I second the idea of some SSDs. Evan, my guess is that your failure problems are probably mechanical and that an SSD, having no moving parts, will fix this.
Another idea might be to look into laptop drives. The smaller disks have less flex in them and I've never had a laptop drive die on me, and my laptop has fallen on the floor several times. That said, laptops typically have G sensors that spin down the hard drive when they detect free fall. Not sure if that is built into the drive, or an extra sensor in the laptop.
IBM made all kinds of drives, not just enterprise ones.
For the record, rumors have it that Hitachi's drive division is probably going to be sold to Western Digital soon.
The Lacie enclosures are pretty good, but the drives inside suck. They likely would have failed even if you just had them sitting on a desk and not traveling. Get a good pair of laptop sized drives and stick it in the lacie enclosures you have (you DO still have them right?) and have a main and a backup. Hitachi and seagate seem to be the most reliable, in that order. If you are multitracking then remember to get at least 7200 rpm drives.
I thought he already has? Evan, aren't you on like your 5th SC48? :lol:
For years I'd used Western Digital 3.5" drives with good results. Based on that experience I started buying WD external drives. Uggg.
I've had 2 Acom external firewire drives die, one was drive the other was controller. I own 1 Lacie and it's used as a record drive twice a year. Still working, but the experience of others led me to back it up to another drive (2 copies + original).
Moved to Seagate external drives and so far are happy with them (but the just sit on the desk most of the time). YMMV.
Where is he going to find a 1 terabyte external SSD? And if he does, how much is it going to cost? $800? $900? More probably?
edit: here's one on Newegg an OCZ for $2,419.
Get one of the enclosures that can do RAID1. They aren't expensive, drives are cheap, and they're barely larger than a single drive. And you will have a mirrored copy of all your data all the time.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817332018
AMS is excellent, highly recommended...
Edit: if you really care about your data (like I do), you should be touring with a server with a RAID 5 or RAID 6 array. A separate shock rack for a 4U computer shouldn't be that big of a deal, and you will be guaranteed to never lose data. Make it a 6U rack and stick a UPS in there too.
