Screwdriver size for M2000 top panel.
Chris Nixon
299
Northern Ireland
This is a bit simple to be called "DIY" but I'm trying to get into a TC M2000 and I don't seem to have the correct size screwdriver for the top panel screws. They look like phillips heads and are 2mm from the end of one "leg" to the other. They do have the 45 degree pozi type marks between the legs but those don't have any real depth that would accept a driver. I've ordered a phillips size PH0, PH1, PH2 and PH3 because I'll need them anyway, but if it isn't one of those would anyone happen to know what I'd need?
Is there some sort of formula for relating the dimensions of a screw head to the size number of the driver you need?
Chris
