Installs
Sealing a 4-gang electrical enclosure around front panel
<blockquote data-quote="Daniel Postilnik" data-source="post: 8374" data-attributes="member: 184"><p>I'm having issues with the remote control devices for a certain manufacturer's DSP unit behaving erratically when exposed to sweat and moisture. It could be argued that the manufacturer needs to step up and make a more robust volume controller, but that's not going to happen.</p><p></p><p>We have a source select and three volume knob controllers housed in a 4-gang enclosure. From the looks of it, the rear part of the assembly is a weatherproof enclosure. However, the front plate is just a quadruple gang wall plate: <a href="http://www.amazon.com/Leviton-80412-W-Wallplate-Standard-Thermoset/dp/B00006JPOA/ref=pd_sim_sbs_hi_7" target="_blank">Amazon.com: Leviton 80412-W 4-Gang Decora/GFCI Device Decora Wallplate, Standard Size, Thermoset, Device Mount, White: Home Improvement</a></p><p></p><p>I believe that sweat is leaking in through the front panel at the edges on the front face of each volume controller, and through the seam where the wall panel attaches to the rear part of the enclosure. Is there some kind of rubber seal that could be inserted behind the wall plate but in front of the volume controllers? It could just be a rubber rectangle with holes in the corner, I just wanted to see if anyone knew of a specific product that already exists.</p><p></p><p>Thanks.</p></blockquote><p></p>
[QUOTE="Daniel Postilnik, post: 8374, member: 184"] I'm having issues with the remote control devices for a certain manufacturer's DSP unit behaving erratically when exposed to sweat and moisture. It could be argued that the manufacturer needs to step up and make a more robust volume controller, but that's not going to happen. We have a source select and three volume knob controllers housed in a 4-gang enclosure. From the looks of it, the rear part of the assembly is a weatherproof enclosure. However, the front plate is just a quadruple gang wall plate: [url=http://www.amazon.com/Leviton-80412-W-Wallplate-Standard-Thermoset/dp/B00006JPOA/ref=pd_sim_sbs_hi_7]Amazon.com: Leviton 80412-W 4-Gang Decora/GFCI Device Decora Wallplate, Standard Size, Thermoset, Device Mount, White: Home Improvement[/url] I believe that sweat is leaking in through the front panel at the edges on the front face of each volume controller, and through the seam where the wall panel attaches to the rear part of the enclosure. Is there some kind of rubber seal that could be inserted behind the wall plate but in front of the volume controllers? It could just be a rubber rectangle with holes in the corner, I just wanted to see if anyone knew of a specific product that already exists. Thanks. [/QUOTE]
Installs
