Lighting & Electrical
Single and Three Phase power conection questions?
<blockquote data-quote="Matt Vivlamore" data-source="post: 4943" data-attributes="member: 33"><p>Help me learn and educate myself on Power for Event Production; aka what can I and can’t I do? I had a “situation” arise this weekend at the venue. The Party/Tent rental company provided a 45kW generator (WhisperWatt) for the event and they provided a Power Distro as well. The generator was set-up to run the provided Power Distro on 3-Phase 208/120 Volt because the Catering Company needed to use an L21-30 plug for one of their warmers/cookers. Originally it was planned for me to pull power off the 50-Amp Cali Plug; HOWEVER it only functions when the Single Phase switch is selected. Anyways, I ended up tagging off the main PD with 4 Extension Cords and the event happened without any problems.</p><p></p><p>By the end of this year I want to be versatile with power and be able to connect almost anything out there. I have a good understanding of Single Phase in 120 and 240.</p><p></p><p>I am confused 3 Phase power and this is where I need help, but I do know that if the 3-Phase is 208 there are 3 hot legs of 120v with a Neutral and Ground.</p><p></p><p>So to start the questions… </p><p>If I go into a Venue or on a Generator with 5 tails pushing out 3-phase 208 (because it meters 120v across a Hot and the Neutral). Can I connect to the Red, Black, White & Green and power my single phase distro?</p><p></p><p>If it is 277/480 – 3 Phase; how is it possible to drop it down to a usable 120v? Or should I just avoid this at all cost.</p></blockquote><p></p>
[QUOTE="Matt Vivlamore, post: 4943, member: 33"] Help me learn and educate myself on Power for Event Production; aka what can I and can’t I do? I had a “situation” arise this weekend at the venue. The Party/Tent rental company provided a 45kW generator (WhisperWatt) for the event and they provided a Power Distro as well. The generator was set-up to run the provided Power Distro on 3-Phase 208/120 Volt because the Catering Company needed to use an L21-30 plug for one of their warmers/cookers. Originally it was planned for me to pull power off the 50-Amp Cali Plug; HOWEVER it only functions when the Single Phase switch is selected. Anyways, I ended up tagging off the main PD with 4 Extension Cords and the event happened without any problems. By the end of this year I want to be versatile with power and be able to connect almost anything out there. I have a good understanding of Single Phase in 120 and 240. I am confused 3 Phase power and this is where I need help, but I do know that if the 3-Phase is 208 there are 3 hot legs of 120v with a Neutral and Ground. So to start the questions… If I go into a Venue or on a Generator with 5 tails pushing out 3-phase 208 (because it meters 120v across a Hot and the Neutral). Can I connect to the Red, Black, White & Green and power my single phase distro? If it is 277/480 – 3 Phase; how is it possible to drop it down to a usable 120v? Or should I just avoid this at all cost. [/QUOTE]
