Lighting & Electrical
Single channel dimmer recommendations
<blockquote data-quote="Brian Bolly" data-source="post: 8817" data-attributes="member: 32"><p>For those times you need to put a single traditional fixture somewhere and need to control it more than just plugging it into the wall, what are you using for dimmers?</p><p></p><p>I've seen the following dimmers, but have no experience with any of them:</p><p></p><p>- Elation Uni Bar</p><p>- Irradiant DMX One</p><p>- Elation/ADJ UniPak II</p><p></p><p></p><p>The ability to put one or two 575w fixtures into one of these things is pretty attractive. I like the Uni Bar and UniPak II because you can seemingly use them without even a controller if necessary. Any comments on the usability/reliability of any of these, or recommendations on any other packs?</p></blockquote><p></p>
[QUOTE="Brian Bolly, post: 8817, member: 32"] For those times you need to put a single traditional fixture somewhere and need to control it more than just plugging it into the wall, what are you using for dimmers? I've seen the following dimmers, but have no experience with any of them: - Elation Uni Bar - Irradiant DMX One - Elation/ADJ UniPak II The ability to put one or two 575w fixtures into one of these things is pretty attractive. I like the Uni Bar and UniPak II because you can seemingly use them without even a controller if necessary. Any comments on the usability/reliability of any of these, or recommendations on any other packs? [/QUOTE]
