SMAART v.7.5.2 and v.7 DI 1.1 RELEASE OVERVIEW
Chris Tsanjoures
45
2
8
Putnam, CT
We have released FREE updates for both Smaart v7 and Smaart v7 Di. Both are recommended for all v7 and/or v7 Di users.
A detailed list of the new features and bug fixes for each release is included below. Smaart v7 Di 1.1 is a major version upgrade and recommend for all v7 Di users.
SMAART V7 DI:
This update includes all of the Real Time Mode features that were added to the full v7 program in the 7.5 update. Smaart v7 Di 1.1 also includes the long awaited v7 Di API. There is no licensing change for this update, simply follow the normal update instructions below.
Note: Due to functional differences between Smaart v7 and v7 Di, the Di API is not identical to the v7 API. Existing third-party programs that include integration with the v7 API will not work with DI until the manufacturer of that program includes the ability to connect to the DI API. All existing SDK recipients have been notified of this change in advance.
• Added Smaart v7 Di API
Allows third party programs the ability to query and issue basic command to any operating copy or v7 Di (Host) as well as request the output data of any of its running measurements (graphics)Screen Shot 2014-07-29 at 2.30.58 PM.png
• Added Normalize function for TF measurements
Holding the Shift key and clicking anywhere on the Magnitude plot Normalizes all visible traces to 0 dB at that frequency.
• Added Quick Compare for TF measurements (Trace Subtract)
Quick Compare captures a copy of the top Transfer Function trace and stores the inverse in memory as a weighting curve. This curve can be quickly applied as a global weighting curve to all live Transfer Function measurements. See the help file topic "Weighting Curves" for more information.
• Added Target Curves on RTA plots
Import ASCII traces into Smaart and display them in a static position on the RTA plot to serve as a visual target or threshold for your single-channel measurements. Curves are managed from Options -> Target Curves and are toggled with the X hotkey.
• Live IR plot can now occupy a proportional amount of space when viewing multiple plots Screen Shot 2014-07-29 at 2.38.36 PM.png
The Live IR plot can occupy 1/3 or 1/2 of the plot space when viewed with another TF plot. This feature is enabled by checking "Proportional Panes" in Transfer Function Options.
• Added Configuration Management
Save as/Restore default on current configuration. Recall, delete and copy functions for stored configs.
• Hover text on Trace Folders (useful when using long folder names)
Hovering your cursor over Trace Folders displays information text similar to Trace Info text.
• Improved Fractional Octave Smoothing
• Improved Coherence-Weighted Averaging
• Improved Integrated Averaging (1 sec, 2 sec, etc)
• Changed Mag Range in TF Options to be a Customizable Default
• Changed Smaart IO to be Default Output Device for Signal generator (When Connected)
For more information about these new v7 Di features, please review Smaart's built-in Help File.
SMAART V7
Smaart v7.5.2 is now available for download. The 7.5.2 update is a minor update with a few important bug fixes.
• Fixed bug where IR ETC would not calculate for certain filters
• Fixed bug where Normalize wouldn't work if only one trace was being shown
• Fixed bug where global weighting was being applied to loaded traces
• Fixed smoothing bug with measurements falling below magnitude threshold
Update Instructions (applicable to both Smaart v7 and v7 DI)
1. Log into your account at http://my.rationalacoustics.com.
2. Select “Your Software Licenses” on the main navigation bar.
3. Click on your Smaart v.7 or Smaart v7 Di license in your list of registered products.
4. On your Smaart License page, scroll down to find the link to download the latest installer (Mac or Windows)
5. Install the new version by running the installer program (Windows) or dragging the new version from the disk image into your Applications folder (Mac).
6. It is NOT necessary to deactivate or re-activate your installation or re-register your v.7 or v.7 Di License.
