I am seeing ads for a lot of new small line array cabs. A lot if them are very small vertically, which seems would lead to less lower frequency pattern control as the actual arrays get smaller.
Am I wrong about this?
The thing that people "forget" is that it is the TOTAL height-NOT the number of boxes that gives the "line array effect".
So if you are using smaller boxes-it will take more of them to "have the same result".
But the marketing depts try to "gloss over" that aspect.
The physics don't change because the box is smaller.
But since they are less expensive-people can buy the same number and spend less-of course the performance is also less--------------------------
But as soon as one person started selling "mini line arrays" everybody "jumped on board". Just another example of "me too" mentality---------------
What also isn't equal is weight, hanging flexibility, amp channels required, etc. There are still a few reasons to buy smaller than 4889, if you don't need a 140dB+ PA.Back when we were shopping for line arrays, I observed that you purchase "by the foot." You can get a lot of smaller boxes for about the same $$$ as fewer big boxes that equal the same length. What isn't equal is the output capability.
And when you add in the fact that the HFs are going to have a lot more separation (due to the thickness of the top and bottom of the cabinet and any spacing in between) than a fewer number of larger boxes-resulting in less clarity (specifically in the HF), then the advantage is ----------------Back when we were shopping for line arrays, I observed that you purchase "by the foot." You can get a lot of smaller boxes for about the same $$$ as fewer big boxes that equal the same length. What isn't equal is the output capability.
Why not?-you do realize that inverse square losses are a major problem with headphones-----------------What next, line array headphones?
I do agree that a few products like the Vue 4" thing are a little odd, and am not sure what application that product is the best choice for.
Note to all, someone please restrain Bennett or remove him from the area if he comes into contact with a ground stacked system.If the PA has to be ground stacked I want to commit suicide.
It's the natural progression of people assuming line arrays as 'better'. Plus it sells more boxes/drivers/amps/processing.
Pretty soon we'll have line array computer speakers, for goodness' sake! What next, line array headphones?
The next "line" product was the "line array microphone" - have fun and good luck
I am not certain if the above is humour or not. Microtech Gefell has been selling the model KEM970 microphone for several years. It is a line array microphone.
KEM970
Linearly writing,
Andre
