I think it is an EAW. My second guess would be EV. No idea what model.
What happened?
Shmoked em. That toggle switch is looking pretty sloppy. What happened ?
Its eaw, sm 200iv monitor
I'd recommend mounting(GOOP brand adhesive or silicone) the two charred resistors up on a piece of aluminum extrusion, and use standoffs to mount them the board. Better heat dissipation.
John
Swapping a crossover designed for a particular product with a genaric one is not generally a good idea.
I would use Johns recommendation and just replace the values-EXCEPT I would change the power capacity of the resistor(s). Whatever the ohmage value is-I would double it-and use twice as many as origional.
This will keep them running cooler. And increase the voltage rating on the cap. 400V should be fine for a monitor.
I second the use of silicon (as John said)-I don't know about Goop. Silicone is very stable under very high temps-just stick a solidering iron into a hardened "blob" and see what happens. Essentially nothing.
The best a general purpose crossover can do is to "assume" that the amplitude and impedance of the drivers is "perfect". Of which they are not-and in many cases not even close.
So the response will often be quite different than what you hope it would be.
Sure is, I just reworked a pair of those crossovers, same problem, same components. Factory replacements were three months out, so I just replaced with the same values, or darned close, and in the case of the caps, used Solen 400v versions.
Customer said they set them up for a DJ's monitors. I suspect there was no sub in that set up, and they just hammered them.
Best regards,
John
PS. They blew one of the 12" drivers as well.
I understand that and realize it for sure.
At the same time if the crossover is designed around a particular component, be it a 15, 6'' or a horn at the time of manufacture. Eaw does not build there own speakers, they use many brands. So when we blew a eminence 15 in a eaw la 325 the original 15 was replaced by a different model. We used it, but there was no change to the cross over. When you toast the 6'' Fostek I believe? in a 325, the replacement is now a b+c lc-0652. Again, eaw does not have a change in the crossover design, I was told, it will work.
So, what gives here?
Thanks.
They use the transducer with the closest Thiele/Small parameter match they can come up with. For recent/current models that can mean a custom batch, for legacy models it's "closest production unit."
So less then as perfect as it was in the begining?
Recone kit from EAW for the factory original ATC driver, done in our shop by one of the best reconers in the biz.John,
Was the eaw 12'' replacement a Identical 12'' or something different?
You'd have to ask EAW about that.
