Since we are showing old homebrew amps. Here is one that I built back in the very early 80's. It is 4 100 watt amps @ 4 ohms ea. The heat sink is made out of a STOP sign. You can make it out if you look close enough. The front of the amp (rack side) is removed.View attachment 2763
I made an amp from a kit back when I was in high school. The sheet metal part of the chassis was one of my first projects in the metal shop class if I recall correctly. We ended up calling this the Refrigerator Amp on account of the fridge door handle I put on the front of it. Many years ago I gave it to my brother to drive his subs in his home stereo. When he came around for the holidays this year he brought it back because it recently quit working. I'm not sure whether to be proud or embarrassed but 20+ years of service ain't bad...
2 transformers but one set of caps? Was the stop sign aluminum? Interesting idea.
I'll have to dig up a photo of a "different" approach I used for a little while. It was power amps with an outboard power supply. It sat beside the amp rack. Two very large transformers and a bank of caps. I think the power supply weighed around 100lbs or more. I ran 2 6x100 watt amps off of it. So the amps weren't all that large- 3 spaces each.I see your refrigerator handle and raise you these two bad boys.
You can't see the amp that well in the pictures, on the left side of front facing photo, and in the middle of the other.. You can see one of my Bose knock off DIY speakers, but with 16 drivers each instead of 9 for 7 more, of course.
My amp that I made back in the early '70s was built into an old WE Power supply chassis so 19" wide and about 2 feet high. I only had one transformer in it, but that transformer alone weighed 65#. Amp made 4 channels of 250W into 8 Ohms, decent power for a home hifi back in those days.
Amp is still working (or at least it was the last time I turned it on), I don't enjoy playing CDs as much since having live bands in my living room.
Any thief who can lift this and run away with it, can have it with my compliments and respect.
