Sound Analysis
John Jones
Hi, I had ran a few tests. My SPL levels are almost identical, yet when I ran the new setup, it was not as loud as the old setup.
I noticed a big drop between 100Hz and 500Hz. How does these frequencys effect a humans ability to hear sound.
Am I correct in saying the new setup has attenuated more sound then the old setup?
Please see PDF View attachment Sound Attenuation.pdf
Much Appreciated.
Re: Sound Analysis
Please see PDF View attachment 8613
Much Appreciated.
I don't want your candy and I'm not getting into your van.
MOM!!!!
Re: Sound Analysis
John,
There indeed is less low mid level wherever the "new" measurement was taken.
Attenuation is generally used as a term for reduction in amplitude prior to amplification.
The low mid reduction in your "new setup" could be from floor bounce (dual path length interference) or from a different proximity from walls, reducing low mid reinforcement.
Or it could be a difference in mic location..
Your measured differences are large, a 10 dB difference at 1000 Hz sounds around half or twice as loud, at 20 Hz a 5 dB difference sounds half or twice as loud.
The chart below shows how average hearing responds to different levels.
Art
