My amp is putting out 2100w at 4 ohms and I'm running that into a double 18 sub containing two speakers running in parallel 8 ohms 1000w peak.
I can use the DSP to limit the audio so the amp never runs into the red, but by my maths, that's still a little on the over powered side (if the 1000w speaker should ideally be paired with an amp that puts out around 700w peak, the halfway point between the speaker's RMS and peak rating). I could lower the limiting threshold further, but this will cost me volume, and arguably increase RMS in a bad way (if DJs drive it hard trying to get that missing volume back).
This set up blew one speaker in a double 18 before I got involved, and it would appear we've blown another one since I applied the limiting, although I think this speaker might have blown because the internal wiring turned out to be 4 pole, so one 1000w speaker was getting power meant for 2. Still, I'd like to say with more confidence to the owner of the PA "this will protect your system" so I am here to ask, where/how do I set the limiter? Is there even a way to protect against too much RMS? Is limiting all I need to do? How do I get maximum volume whilst still preserving the speakers?
