On the stage they sat. Two quad boxes, steel, with three prong receptacles. Attached was a three hundred foot piece of 14 -2 mc cable. Hmmm. Can you say "brown out?" Sure you can.
I never, ever, ever, ever, ever ( ya feel me?) plug in without checking for proper voltage and wiring. SO, since the event coordinators shared that the "house electrician" had placed these drops, I pondered - does Mr. Electrician know how to wire these up?
Mr. Fluke meter is brought to the stage, I open the pouch, pull the meter out and turn it to AC setting. I then, with left hand, pick up one of the steel quads and ZAAAAAAP! rassin' frassin' g....d....s..o..b...m..f...x*&##%$@@
WTH? Hit like a punch from Tyson. This is not 120v. This is easily 240. I could barely let go of the box.
I follow the MC cable to a light post in the main yard (sorry, this was an out door Catholic festival) and.....voila....it is stripped, no bushing and tied into a 277v feed, no neutral or ground connection. NO NEUTRAL OR GROUND CONNECTION!
Even better ...no GFCI protection for the band or victim.
I disconnect MR. Electricians feed, go back open the box and see the black 14 wire tied to the silver screw of the receptacle.....heh, heh...(for you uninformed types, that's the neutral side of the receptacle. WHICH MEANS WHEN YOU THEN ATTACH THE GROUND SCREW TO THE METAL BOX, ENERGIZE THE CIRCUIT AND TOUCH THE THING...YOU SAY BAD WORDS.....
I share this only to remind you that even though I was an electrician for 11 years, I failed in making any contact with that box. I could have checked voltage easily without touching the damn thing. SO, having learned another valuable lession and getting my ventricular tachycardia back to normal, I will be even safer next time...
you do the same...
have fun out there...
trust noone...
now come help me bury the body of the "house electrician"
Steve
you do the same...
trust noone...
Steve
