Re: Spray system for painting cabs/ cases
Hey Dan,
On the cheap side of things, I use a regular Harbor Freight paint sprayer with my compressor and have Home Depot mix me up some $20/ gallon semi-gloss latex Glidden paint with "black onyx" tint.
I think Duratex makes a product that works in a spray gun that is probably more durable at a slightly higher cost.
I have had good results with Home Depot's Behr paint, "Beluga" is their all lamp black color.
Duratex is better, but the cost went up on the last gallon I bought, $52.50 plus $19.09 S&H. Duratex sticks well to other latex paint, so I have used cheaper paints for the first coat.
I could not get the last spray gun I bought to work for more than a few minutes without clogging using latex, so I have been using pad brushes for the initial coat and a little texture roller from Duratex for the finish coats. Looks good, and for the amount of painting I generally do at once, saves time over getting a spray gun set up properly, and then cleaning it. The texture roller is almost as fast as laying down a swath of paint with a spray gun, and a lot faster than spray cans.
Painting black cabinets without really good light is a bad idea.
The photo below shows my first attempt with Duratex, and a roller, later attempts (like any skill) were better looking. You can see a few spots I hit with a spray can after finding I missed some spots that the sun showed to be wood color .
The Rustoleum Satin Black spray paint matches semi gloss Beluga perfectly, but not Duratex black :^(.
Art
