Re: Square horn rotation
I came across some homemade speakers. There's nothing special about them, its just that i think the horn rotation is wrong (by 90 degrees), but I'm not sure. The speaker should have wider horizontal than vertical dispersion.
As Art said- you cannot just go by looks.
The sad fact is that MOST horns are built completely WRONG dimension wise (I am not talking the type of flare here-just the basic exit dimension.
If you have a horn that is rated for 90wide x 45 tall then it "should" be TWICE as TALL as it is wide-in order for the pattern to avoid pattern flip-as Art said.
Pattern flip is something that most manufacturers do not pay any attention to-and therefore the industry has come to "accept" the completely WRONG performance.
Historically there have been a few that have been correct. The earliest ones that I remember were some EV products back in the 80s. And people used to comment on how weird they looked-even though they PERFORMED correctly.
I believe Renkus Heinz was the first to start pushing the idea and showing it in their literature.
And while I am at it-in most cases the idea of a "rotatable horn" is just funny and shows how gullible the average consumer is and how the manufacturer is simply willing to give them what they want-no matter how "wrong" it is.
Unless the horn is large enough, the only freq you are "rotating" are often in the top octave or two. Does that REALLY do what you "think" you want?
Since the narrower pattern needs to be the largest dimension-this means that it often has very little actual control over the freq of real interest.
But as long as people "think" they are getting something-and don't ever bother to check-manufacturers will continue to give it to them.
Just like a "mini line array"-but we won't go there---------------------
